Title
You can enter the title of the field under the title option in settings.
Text Alignment
Text alignment helps you to position the text in its appropriate place (Left, Centre, Right).
Text Style
Use the text style option to change the style to your needs.
Font Size
Use the font size option to set the size of the text.
Placeholder
The Placeholder is a text displayed inside the text field. It gives more information about the text and the details that need to be collected by that field. The text disappears once the user starts typing. The user can edit the placeholder text to their needs by clicking on the settings of that field.
Required Field
Required fields are highlighted in red beside the title of the field. To make the field required click on the required option in the field settings.
Fill all the required fields. If you don’t fill in the required details it will be highlighted in red and you cannot proceed with the submission.
Maximum Characters
You can limit the text a user can add in the field, by setting the maximum number of characters in the field’s settings section on the right side.
Delete Option
Click on the delete option to remove the field from the form.
Once you click on the delete option, a warning message pops up in the page asking for confirmation to delete the field. Hit the “Yes” button to delete the field, or “No” to cancel it.
Related Articles
How Do Form Fields Work?
Form fields are the essential elements in the form builder. They help you to collect information from the user who fills out the form. On Formclick, you can find the form fields under the title “Fields” on the left side of the page. Header Header ...
How to Create a New Form?
This article shows you how to create a new form step by step. To create a new form, click the New Template button on the top right corner of the page. The new template button leads to the create new template option. Enter the form title, select the ...
How To Update or Change Forms Details?
General settings consist of the details of the form. You can change the name and status of the form in the settings. To access the settings, click on the settings and go to the general settings page. Click on the general option, update the profile ...
How To Create and Manage Submissions?
This article shows you the step-by-step process of the submission of the form. To submit a form, go to the form and click on the submission option. The Form Submission page has the records of previous submissions. To create a new submission, click ...
How To Update The User’s Profile?
Profile page consists of the personal information and account details of the user. To update or change the profile, click on the profile icon and go settings. Click on the profile option, update your details and save the changes.
